[Qgis-user] two problems
Donovan Cameron
sault.don at gmail.com
Wed Aug 6 16:17:21 PDT 2014
I've noticed some users reporting that error too.
But I use a custom build of grass 6 which I've uploaded to my dropbox[1]
- can you give it a try?
I can't figure out why QGIS has trouble finding that folder during
configuration.
As for the sip error... One of the QGIS dependencies is python2-sip so
it should be able to import the sip module when it starts.
Are you able to run...
% python2
>>> import sip
...without errors?
Donovan
[1] https://db.tt/ClXi7MsC
On 06/08/14 03:44 PM, Tomas Lanczos wrote:
> Hello everybody.
> I'd like to install qgis 2.4 on my Manjaro box, using the AUR (Arch
> linux) repository - https://aur.archlinux.org/packages/qgis/
> In fact, it is a compilation process, with a source cod downloaded from
> git://github.com/qgis/QGIS.git#branch=release-2_4
> <http://github.com/qgis/QGIS.git#branch=release-2_4>
> PROBLEM NO. 1
> if I compile it without grass support, the compilation/installation
> process is going out without problem, but after starting qgis, I got
> the following error message:
> ouldn't load SIP module.
> Python support will be disabled.
> Traceback (most recent call last):
> File "", line 1, in
> ImportError: No module named sip
> Python version:
> 2.7.8 (default, Jul 1 2014, 17:30:21)
> [GCC 4.9.0 20140604 (prerelease)]
> QGIS version:
> 2.4.0-Chugiak 'Chugiak', ed14cf3
> Python path:
> ['/usr/share/qgis/python', u'/home/tomas/.qgis2/python',
> u'/home/tomas/.qgis2/python/plugins',
> '/usr/share/qgis/python/plugins', '/home/tomas',
> '/usr/share/qgis/python', '/usr/local/lib/python27.zip',
> '/usr/local/lib/python2.7', '/usr/local/lib/python2.7/plat-linux2',
> '/usr/local/lib/python2.7/lib-tk', '/usr/local/lib/python2.7/lib-old',
> '/usr/local/lib/python2.7/lib-dynload',
> '/usr/local/lib/python2.7/site-packages']
> PROBLEM No.2
> It is essential for me to use qgis with grass support, so I tried to
> compile qgis with the following options:
> cmake ../ \
> -DCMAKE_BUILD_TYPE=Release \
> -DCMAKE_SKIP_RPATH=ON \
> -DCMAKE_INSTALL_PREFIX=/usr \
> -DENABLE_TESTS=OFF \
> -DQGIS_MANUAL_SUBDIR=share/man \
> -DPYTHON_EXECUTABLE=/usr/bin/python2 \
> -DPYTHON_LIBRARY=/usr/lib/libpython2.7.so <http://libpython2.7.so> \
> -DPYTHON_INCLUDE_PATH=/usr/include/python2.7 \
> -DPYTHON_SITE_PACKAGES_DIR=/usr/lib/python2.7/site-packages \
> -DQT_QMAKE_EXECUTABLE=/usr/bin/qmake-qt4 \
> -DWITH_INTERNAL_QWTPOLAR=OFF \
> -DWITH_INTERNAL_SPATIALITE=OFF \
> # -DWITH_MAPSERVER=TRUE \
> -DGRASS_PREFIX=/opt/grass64 \
> # -DWITH_GLOBE=TRUE \
> In this case I'm getting this errormessage after the configuring process:
> -- Configuring done
> -- Generating done
> -- Build files have been written to:
> /home/tomas/builds/qgis/src/qgis/build
> /home/tomas/builds/qgis/PKGBUILD: line 98:
> -DGRASS_PREFIX=/opt/grass64: No such file or directory
> ==> ERROR: A failure occurred in build().
> Aborting...
> The strange thing is that, the "/opt/grass64" directory is existing,
> but it can't locate it.
> Many thanks in advance for any feedback
> Tomas
> Water, taken in moderation cannot hurt anybody.
> -- Mark Twain
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140806/86ad7e13/attachment.html>
