[Qgis-user] R: Re: R: Re: R: Re: Formatting pc
labiancamarilena at libero.it labiancamarilena at libero.it
Mon Aug 11 09:10:02 PDT 2014
Dear Paolo,
I've actually tried the plugin with a very complex project with a lot of data,
and then probably some data were not recovered properly.
I will try with a simpler project, but I'm really afraid of losing some data
after these operations.
Thank you so much for the help.
Marilena
>----Messaggio originale----
>Da: cavallini at faunalia.it
>Data: 11/08/2014 13.57
>A: "labiancamarilena at libero.it"<labiancamarilena at libero.it>, <qgis-user at lists.
osgeo.org>
>Ogg: Re: R: Re: R: Re: [Qgis-user] Formatting pc
>Il 11/08/2014 13:20, labiancamarilena at libero.it ha scritto:
>> Dear Paolo,
>> thanks a lot.
>>  I began to use this plugin.
>> It allows you to put together the project and sources of data.
>> It works quite well, but  unfortunately there are  some shapefile that
once
>> you open the project are corrupted.
>That's weird. Could you please create a test case, ideally with a very small
project
>with only one small shapefile, before and after moving it with the plugin?
>Thanks.
>Paolo Cavallini - www.faunalia.eu
>Corsi QGIS e PostGIS: http://www.faunalia.eu/training.html
