[Qgis-user] QGIS from External drive ?
Alex Mandel
tech_dev at wildintellect.com
Mon Aug 11 13:09:40 PDT 2014
You might want to contact Hamish in New Zealand.
He also does ship based GIS, and is a core contributor to OSGeo-Live
partly because he uses it on research missions. It can be run from an
external drive (including flash drive), it just requires rebooting the
computer.
Thanks,
Alex
On 08/11/2014 12:52 PM, Falk Huettmann wrote:
> Wow, thanks so much.
> That would be a big help.
> (We need it on a ship, and installations there are weird).
> So a plain PC laptop run via an external drive would be the way to go.
> Thanks once more; kindly
> F.
> *From:* luca forestello [mailto:fraelu at gmail.com]
> *Sent:* Monday, August 11, 2014 1:25 AM
> *To:* qgis-user at lists.osgeo.org; fhuettmann at alaska.edu
> *Subject:* Re: [Qgis-user] QGIS from External drive ?
> On Windows,
> you can try this version of Qgis 2.4 that not requires installation and
> does not require administrative privileges.
> http://webgis.arpa.piemonte.it/pub/QGIS_portable_Chugiak_24_32bit.zip
> You need to download the file "qgis_portable.zip", unzip the file (for
> example, C:\Program Files\Qgis_portable, USB or external HD should be the
> same thing).
> At the end of this operation, which can take several minutes, in the folder
> "qgis_portable", you will find a new folder "QGIS" and a new file
> "qgis.bat" (MS-DOS Batch File).
> To start Qgis 2.4 simply double-click on the file "qgis.bat."
> Kind regards
> Luca Forestello
> Qgis-user mailing list
