[Qgis-user] Label rendering
Larry Shaffer
larrys at dakotacarto.com
Tue Aug 12 22:56:48 PDT 2014
Hi Les,
With the current implementation, labeling is always draw last, on top of
all other symbology layers. This is due to the fact that the automated
solution for placing labels is done after all layers have registered their
features. Otherwise, labeling would need to be solved prior to rendering
any symbology of any layer, which would slow the overall apparent speed of
rendering in many cases.
Still, it is possible to implement labeling per layer. Just hasn't been
attempted, yet.
Regards,
Larry Shaffer
Dakota Cartography
Black Hills, South Dakota
On Tue, Aug 12, 2014 at 9:33 PM, les at true3d.com.au <les at true3d.com.au>
wrote:
> Hi List,
> I am creating a road map and I am having trouble with the road labels. I
> am using QGIS 2.4 Chugiak on a windows PC. I am using the Layer Order
> window to control the rendering order and this works fine for all the
> other layers.
> With the road layer, the lines render at the correct level however the
> corresponding labels render on top of ALL other layers. What am I doing
> wrong that the labels do not render at the same level as the road lines.
> Regards,
> Les Searle
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140812/b38bf183/attachment.html>
