[Qgis-user] Expression in composer - add attributes from layer or external file
Alexandre Neto senhor.neto at gmail.com
Wed Aug 13 15:19:44 PDT 2014
Hello Antonio,
Just asking the obvious but, is the layer the atlas coverage layer? If not,
maybe you can make it so, even if you don't use it to control the any of
the maps, and you will have all his attributes available in the expression
builder (at least I think so).
Best regards,
Alexandre Neto
On Wed, Aug 13, 2014 at 10:22 PM, AntonioLocandro <
antoniolocandro at hotmail.com> wrote:
> Is there a way to add attributes from a layer in the proyect (preferable)
> or
> an external csv to the composer using insert expression? Cant seem to find
> an option to do so
> http://osgeo-org.1560.x6.nabble.com/Expression-in-composer-add-attributes-from-layer-or-external-file-tp5156270.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140813/5a30f8b8/attachment.html>
