[Qgis-user] QGIS 2.2 and 2.4 - apparent mistake? Improvements?
Martin Schneppmüller
mstrms2000 at gmail.com
Sat Aug 16 02:44:21 PDT 2014
Hi, I allready asked that in the german fossgis list:
Adjusting of the snap options is cumbersome. During processing it is
sometimes necessary to switch the option off and on again. The shutdown of
the snap option but is not always effective before re saving the project. A
simpler operation of the snap option like a "switch" for quick on and off,
after you have set the basic settings, is more comfortable to make work
easier. Similar to the "redraw" switch next to the scale.
If the rows of a table of attributes are sorted by a column, and you enters
new values into empty fields by the field calculator, eg Coordinates,
then these new values are not displayed in the open table. Only after
saving, closing and re-opening the table, the values are displayed.
Are these bugs?
mfg Martin
http://www.halberstadt.de/
http://www.domverein-halberstadt.de/
http://www.dom-und-domschatz.de/
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140816/d432df50/attachment.html>
