[Qgis-user] print composer
Mike Treglia mtreglia at gmail.com
Sun Aug 17 03:15:05 PDT 2014
Hi Daniel,
Can you provide more details at all? Do you mean that two layers aren't lining up as they should in the print composer but they look fine in the main QGIS window? Or coordinates displayed on the map are not right?
Do you have things in different projections and if so, projection on the fly turned on?
Also, it may be helpful to know which version of QGIS you are working with.
Best
Mike
> On Aug 17, 2014, at 4:02 AM, daniel pinto <daniel.ar.pinto at gmail.com> wrote:
> dear all i need to export a map i created...  in qgis everytinhg is allright but in the print composer all the places appear some meters up to northwest..... i reaaly need to send this today... can someone help??..
> thanks in advance :)
> daniel pinto
> arqueólogo
> tel:96 646 0031 - 91 869 1397
> rua de Arouca, nº 10, 1º esq, 3810-050 - Aveiro
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140817/6c61d502/attachment.html>
