[Qgis-user] print composer
Damien Stephens Damien.Stephens at sandfire.com.au
Sun Aug 17 18:17:32 PDT 2014
Hi Daniel. I assume you are using the open layers plugin.
If so set your map canvas to exactly the same size as the page size. This works for me.
You do this under item properties/position and size.
The attached image is the setup for  A1:
[cid:image001.png at 01CFBABB.561BD8F0]
From: qgis-user-bounces at lists.osgeo.org [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of daniel pinto
Sent: Sunday, 17 August 2014 5:02 PM
To: qgis-user at lists.osgeo.org
Subject: [Qgis-user] print composer
dear all i need to export a map i created...  in qgis everytinhg is allright but in the print composer all the places appear some meters up to northwest..... i reaaly need to send this today... can someone help??..
thanks in advance :)
daniel pinto
arqueólogo
daniel.ar.pinto at gmail.com<mailto:daniel.ar.pinto at gmail.com>
tel:96 646 0031 - 91 869 1397
rua de Arouca, nº 10, 1º esq, 3810-050 - Aveiro
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140818/a06ecc88/attachment.html>
Type: image/png
Desc: image001.png
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140818/a06ecc88/attachment.png>
