[Qgis-user] does someone know why I cannot export maps generated with openlayers plugin?
Damien Stephens
Damien.Stephens at sandfire.com.au
Thu Aug 21 17:28:28 PDT 2014
Hi I have the same setup and am printing without issue.
Can you give a bit more detail?
Which open layers are you using, do you have anything else overlaying it, what grid system are you using.
Will see if I can replicate.
Thanks
Damien
-----Original Message-----
From: qgis-user-bounces at lists.osgeo.org [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of prossini
Sent: Thursday, 21 August 2014 6:04 PM
To: qgis-user at lists.osgeo.org
Subject: [Qgis-user] does someone know why I cannot export maps generated with openlayers plugin?
Hello to everybody,
I'm trying to export maps generated with the openlayers plugin as pdf files (I tried also in svg or png...), but something doesn't work and the composer freezes until I don't restart QGis...
Can someone kindly explain me how can I overcome the problem?
Windows 7 Professional SP1
QGIS 2.4.0-Chugiak
OpenLayers Plugin 1.3.3
many thanks,
Paolo
Dr. Paolo Rossini
Istituto di Ricerca Gruppo CSA
phone +39 0541 791050 fax +39 0541 791045 via Al Torrente 22, 47923 Rimini, Italy www.csaricerche.com
THINK GLOBAL - ACT LOCAL
Qgis-user mailing list
Qgis-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-user
