[Qgis-user] Field calculator QGIS2.4 division error
Nathan Woodrow
madmanwoo at gmail.com
Sat Aug 23 14:03:23 PDT 2014
Yes. You are right. Never mind me.
Nathan
Hi Nathan,
are you sure?
QgsExpression('100.0 * 50 / 3').evaluate()
1666.666666666667
QgsExpression('50 / 3 * 100.0').evaluate()
1600.0
Zoltan
On Sat, 23 Aug 2014, Nathan Woodrow wrote:
Hey,
> There is no left to right here, / is higher order then * so both these are
> the same:
> exp = QgsExpression('100.0 * 50 / 2')
>>> exp2 = QgsExpression('50 / 2 * 100.0')
>>> exp.evaluate(), exp2.evaluate()
>> (2500.0, 2500.0)
> What you are seeing is the QGIS expression engine doing the multiply part
> result first, which returns a float, then it will say "is the left side a
> int AND the right side a int" if that comes back as NO then it does a float
> operation. Basically this means once one of the values in the equation is
> a float the result will come out as float.
> If you want to see the details on how this works you can find it here
> https://github.com/qgis/QGIS/blob/master/src/core/qgsexpression.cpp#L2093
> - Nathan
> On Sat, Aug 23, 2014 at 8:22 PM, ralfwessels <gis at ralf-wessels.de> wrote:
> Hi
>> intereseting, didn't know the left to right rule explained by Zoltan:
>> Siki Zoltan wrote
>>> 100.0 * "HC01_VC04" / "HC01_VC03" will give you the right result.
>>> First the multiplication is evaluated (left to right rule),...
>> Learning never stops!
>> ralf
>> View this message in context:
>> http://osgeo-org.1560.x6.nabble.com/Re-Field-calculator-QGIS2-4-division-
>> error-tp5157715p5157980.html
>> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140824/2e54d68c/attachment.html>
