[Qgis-user] geometry attribute units
Carlos Cerdán sig.upagu at gmail.com
Mon Aug 25 06:05:47 PDT 2014
> The perimeter is calculated in units of the layer. If that has degrees
> (like EPSG:4326), the perimeter result is surely nonsense.
> You have to reproject your datasource to a projected CRS that uses metres,
> feet or miles to get a useful result.
Just a little correction: geometry is not calculated in units of the layer,
but in units of the project. Be sure that "on the fly" reprojection is
disabled. If doesn't, it causes a wrong result (an issue of QGIS that is
not solved yet).
Good luck
Carlos Cerdán
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140825/15adb534/attachment.html>
