[Qgis-user] Qgis-user Digest, Vol 102, Issue 51
prossini
prossini at csaricerche.com
Fri Aug 29 01:02:08 PDT 2014
>Date: Fri, 29 Aug 2014 00:12:16 +0200
>From: Redoute <redoute at tortenboxer.de>
>To: Laura O'Grady <laura at lauraogrady.ca>
>Cc: "qgis-user at lists.osgeo.org" <qgis-user at lists.osgeo.org>
>Subject: Re: [Qgis-user] OpenStreetMap Error
>Message-ID: <53FFA940.3010704 at tortenboxer.de>
>Content-Type: text/plain; charset=ISO-8859-1 Am 28.08.2014 21:44,
schrieb Laura O'Grady:
>> I was only ever able to get it to work for an individual session - when I close the .qgs file with the
>> OSM-related work and re-open it the OSM map tiles are not there. I
> have to re-load as a basemap via the Open Layers menu.
> Actually there is a problem with the OpenLayers plugin. For some users
> OpenLayer layers aren't restored when opening a project.
> See <https://hub.qgis.org/issues/10766>. I suggested a workaround there,
> don't know if it works for others.
> Redoute
Yes, I confirm that the problems with the OpenLayers plugin still remain:
See updates in <https://hub.qgis.org/issues/10766> and
<https://hub.qgis.org/issues/11073>.
Paolo
