[Qgis-user] Newbie - QGIS won't recongize shp files, comp turns shp files into pdfs
Frank Sokolic
sokolic at worldonline.co.za
Sun Jan 5 22:00:22 PST 2014
Hi Matt,
Are you using the "Add Vector Layer" command to open the shapefiles? If
not, go to the "Layer" menu and select the "Add Vector Layer" command.
You can then choose "Browse" to look for the shapefile you want to load.
Regards, Frank.
On 06/01/2014 06:57, Matt_Klick wrote:
> No luck on this yet, but thank you for your suggestion. On another
> computer, I still cannot upload shp files - instead changing them to
> nursoft (??) files. In any event, I cannot yet open a shp file using QGIS.
> On Fri, Jan 3, 2014 at 3:19 PM, Akinyemi Bojerenu [via OSGeo.org]
> <[hidden email] </user/SendEmail.jtp?type=node&node=5096495&i=0>> wrote:
> Hi,
> Please extract the contents of the zip file first into a destination
> folder of choice.
> When opening a shapefile, navigate to your folder to select the
> shapefile(s).
> Hope this helps..
> Yemi
> On Jan 4, 2014 9:13 AM, "Matt_Klick" <[hidden email]
> <http://user/SendEmail.jtp?type=node&node=5096323&i=0>> wrote:
> I'm very new to any GIS type platforms, so please forgive the
> ignorance on
> display here (and I did search for answers to this elsewhere). I've
> downloaded QGIS 2.0.1. I separately downloaded Tunisia
> administrative data
> from DIVA-GIS. When I open QGIS, it does not find the .zip file,
> nor any of
> the shp files. In my efforts to correct, I managed to convert
> shp files into
> pdfs. Even though I've re-installed QGIS, and deleted and
> re-downloaded
> Tunisia files, shp files are once again pdfs, and QGIS cannot
> "see" any shp
> files. Any advice, or thoughts on what I'm doing wrong, greatly
> appreciated.
> -MK
> http://osgeo-org.1560.x6.nabble.com/Newbie-QGIS-won-t-recongize-shp-files-comp-turns-shp-files-into-pdfs-tp5096322.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> Qgis-user mailing list
> [hidden email]
> <http://user/SendEmail.jtp?type=node&node=5096323&i=1>
> [hidden email] <http://user/SendEmail.jtp?type=node&node=5096323&i=2>
> If you reply to this email, your message will be added to the
> discussion below:
> http://osgeo-org.1560.x6.nabble.com/Newbie-QGIS-won-t-recongize-shp-files-comp-turns-shp-files-into-pdfs-tp5096322p5096323.html
> To unsubscribe from Newbie - QGIS won't recongize shp files, comp
> turns shp files into pdfs, click here.
> NAML
> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
> View this message in context: Re: Newbie - QGIS won't recongize shp
> <http://osgeo-org.1560.x6.nabble.com/Newbie-QGIS-won-t-recongize-shp-files-comp-turns-shp-files-into-pdfs-tp5096322p5096495.html>
> <http://osgeo-org.1560.x6.nabble.com/Quantum-GIS-User-f4125267.html> at
> Nabble.com.
