[Qgis-user] [GRASS-user] Python modules problems after last OSX GIS updates
    Carlos Grohmann
    carlos.grohmann at gmail.com
    Tue Jul  1 05:21:55 PDT 2014
Hi there
Sorry, my mistake
It's the Dakota GIS Team who's using a VM. I'd just read that and it got
stuck in my head.
I re-checked it today and William's binaries are working fine (python
complains about LucidaGrande fonte, but that's it):
2014-07-01 09:01:14.232 Python[21856:d0b] CoreText performance note: Client
called CTFontCreateWithName() using name ".Lucida Grande UI" and got font
with PostScript name ".LucidaGrandeUI". For best performance, only use
PostScript names when calling this API.
The problems are actually with Michael Barton's GRASS-7.0 binaries. (I want
to look at the global MOLA dataset, so went with v7.0 since it already has
the planetary bodies listed on the Location wizard)
In it, I can import matplotlib, but this:
import matplotlib.pyplot as plt
gives me this:
  File "<stdin>", line 1, in <module>
  File
"/Library/Python/2.7/site-packages/matplotlib-override/matplotlib/pyplot.py",
line 24, in <module>
    import matplotlib.colorbar
  File
"/Library/Python/2.7/site-packages/matplotlib-override/matplotlib/colorbar.py",
line 27, in <module>
    import matplotlib.artist as martist
  File
"/Library/Python/2.7/site-packages/matplotlib-override/matplotlib/artist.py",
line 8, in <module>
    from transforms import Bbox, IdentityTransform, TransformedBbox, \
  File
"/Library/Python/2.7/site-packages/matplotlib-override/matplotlib/transforms.py",
line 35, in <module>
    from matplotlib._path import (affine_transform,
count_bboxes_overlapping_bbox,
ImportError:
dlopen(/Library/Python/2.7/site-packages/matplotlib-override/matplotlib/_path.so,
2): no suitable image found.  Did find:
 /Library/Python/2.7/site-packages/matplotlib-override/matplotlib/_path.so:
mach-o, but wrong architecture
sorry about the confusion
best
Carlos
On Mon, Jun 30, 2014 at 10:08 PM, Anna Petrášová <kratochanna at gmail.com>
wrote:
> Hi,
> On Mon, Jun 30, 2014 at 7:57 PM, William Kyngesburye <
> woklist at kyngchaos.com> wrote:
>> What are the errors?  Do you have simple examples I can try?  I updated
>> matplotlib and GDAL a month ago and this is the first I've heard of
>> problems.  I am not packaging with a virtual machine.
>> I did hear about GRASS problems.  There are font warnings due to a slip
>> in wxPython bugfixing - fixed for wx Carbon but not wx Cocoa.  I am now
>> using wxPython 3 Cocoa, and I read that there were fixes in GRASS for that
>> version, but maybe there are other problems, or it may be an OS X thing.
> Regarding wxPython3 Cocoa, there is still a lot of problems. I found
> several tickets on wxWidgets which we are affected by and only for some of
> them there is a workaround. WxGUI works only to certain extent, but there
> are problems with dialog modality, map selection widget, toolbars and other
> pretty serious things. On the other hand, wxnviz seems to work pretty well,
> although switching back to 2D mode, makes the GUI unresponsive which is bug
> in a notebook widget, not wxNviz.
>> On Jun 30, 2014, at 3:28 PM, Carlos Grohmann <carlos.grohmann at gmail.com>
>> wrote:
>> > Hello, apologies for cross-posting but this might be happening to other
>> users
>> > After installing the latest packages updates from William Kyngesburye
>> on OSX 10.9 Mavericks, I'm getting lots of errors, both in Matplotlib and
>> GDAL. From what I could see, that all return the "mach-o, but wrong
>> architecture" error, so this might be related to William's recent setup for
>> packaging using a virtual machine.
>> > I'm also getting the some errors with wxpython running GRASS 6.4.4
>> > Unfortunately for me, Matplotlib is pretty much essential, so I'm
>> hoping this issues get fixed soon.
> sorry, no idea about this
> Anna
>> > best
>> > Carlos
>> > Prof. Carlos Henrique Grohmann
>> > Institute of Energy and Environment - Univ. of São Paulo, Brazil
>> > - Digital Terrain Analysis | GIS | Remote Sensing -
>> > http://carlosgrohmann.com
>> > http://orcid.org/0000-0001-5073-5572
>> > ________________
>> > Can’t stop the signal.
>> > _______________________________________________
>> > Qgis-user mailing list
>> > Qgis-user at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/qgis-user
>> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
>> http://www.kyngchaos.com/
>> "Those people who most want to rule people are, ipso-facto, those least
>> suited to do it."
>> - A rule of the universe, from the HitchHiker's Guide to the Galaxy
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
________________
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140701/a87a12d2/attachment.html>
