[Qgis-user] Plugin GEarthView - Error Qgis 2.0.1 on Ubuntu 14.04
Gino Pirelli
luipir at gmail.com
Tue Jul 1 06:36:09 PDT 2014
file a tiket!ç
generally it's due the fact it's not used correct UTF8 decoding of the
string to write...
probably you have not ASCII characters (ascii is the default char coding)
as à or é etc etc in you file.
correct coding/decoding should be managed by the plugin => file a ticket or
modify the code and prepare a pull request.
regards,
Luigi Pirelli (luigi.pirelli at faunalia.it - uipir at gmail.com)
On 1 July 2014 15:04, Carmine Massarelli <carmine.massarelli at ba.irsa.cnr.it>
wrote:
> Dear all,
> I installed Qgis plugin GEarthView but i received this error when I try
> to active it.
> Could you help me to understand what is the problem?
> Currently, I have Qgis 2.0.1 on Ubuntu 14.04.
> Thanks
> Here is the error code:
> Errore durante l'esecuzione di codice Python:
> Traceback (most recent call last):
> File "/home/massarelli/.qgis2/python/plugins/gearthview/gearthview.py",
> line 601, in run
> kml.write (stringazza)
> UnicodeEncodeError: 'ascii' codec can't encode character u'\xe0' in
> position 35: ordinal not in range(128)
> Versione Python:
> 2.7.6 (default, Mar 22 2014, 23:03:41)
> [GCC 4.8.2]
> Versione di QGIS:
> 2.0.1-Dufour Dufour, exported
> Percorso Python: ['/usr/share/qgis/python',
> '/home/massarelli/.qgis2/python', '/home/massarelli/.qgis2/python/plugins',
> '/usr/share/qgis/python/plugins', '/usr/lib/python2.7',
> '/usr/lib/python2.7/plat-x86_64-linux-gnu', '/usr/lib/python2.7/lib-tk',
> '/usr/lib/python2.7/lib-old', '/usr/lib/python2.7/lib-dynload',
> '/usr/local/lib/python2.7/dist-packages',
> '/usr/lib/python2.7/dist-packages',
> '/usr/lib/python2.7/dist-packages/PILcompat',
> '/usr/lib/python2.7/dist-packages/gtk-2.0', '/usr/lib/pymodules/python2.7',
> '/usr/lib/python2.7/dist-packages/ubuntu-sso-client',
> '/usr/lib/python2.7/dist-packages/wx-2.8-gtk2-unicode',
> '/home/massarelli/.qgis2/python/plugins/MetaSearch/ext-libs',
> '/usr/share/qgis/python/plugins/fTools/tools',
> '/home/massarelli/.qgis2/python/plugins/DigitizingTools/tools']
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140701/598abd1f/attachment.html>
