[Qgis-user] pixel counting in a raster
Alex Mandel
tech_dev at wildintellect.com
Wed Jul 2 12:51:11 PDT 2014
With Processing (Included in 2.2+, previously called sextante) you can
access the r.stats or r.report function directly in QGIS. If you don't
see a Processing Menu, you can enable it in the Plugin Manager.
It should be fairly straight foward to pick a loaded raster and get
results back.
Thanks,
Alex
On 07/02/2014 12:07 PM, Marco Antonio wrote:
> Hi, again.
> You'r rigth, is necesary export the raster to a grass location and mapset
> bla bla bla...
> I think there is a tool to do it in Qgis, is an experimental complement
> "processing" [https://hub.qgis.org/projects/sextante/] maybe you should
> install it.
> When installed go to Processing > toolbox.
> In toolbox go to Scripts > [Example scripts]raster processing > Unique
> values count
> Good luck.
> Marco
> 2014-07-01 12:00 GMT-05:00 Giacomo Fontanelli <giacomofontanelli76 at gmail.com
>> Dear Qgis Community
>> I have a Raster layer made by pixels with 4 different values (4, 7, 17,
>> 27).
>> How can i calculate the number of pixels with value 4, with value 7, with
>> value 17, with value 27?
>> Thank you very much
>> Giacomo
