[Qgis-user] Simplified interface - toolbox
Victor Olaya
volayaf at gmail.com
Wed Jul 9 16:24:13 PDT 2014
The issue is actually a packaging issue. There was a problem in the
cmake.txt file, and it is not copying the file that is used to classify the
algorithm in categories in the simplified interface.
The problem should be fixed now, and I guess that we will release a new
version in the following days, which will include this fix and the new
modeler
You can manually fix it by adding the missing file in the gui folder under
the processing folder. In a OSGEO4W installation, that would
be C:\OSGeo4W64\apps\qgis\python\plugins\processing\gui
The file can be found here:
https://raw.githubusercontent.com/qgis/QGIS/master/python/plugins/processing/gui/algclasssification.txt
Thanks for your help
2014-07-09 14:03 GMT+02:00 Jonathan Moules <
jonathanmoules at warwickshire.gov.uk>:
> Ok,
> I've reported it to the tracker:
> https://hub.qgis.org/issues/10854
> Seems like quite a bad bug from a user-interface perspective.
> Thanks,
> Jonathan
> On 9 July 2014 12:33, Randal Hale <rjhale at northrivergeographic.com> wrote:
>> Same Bug on Ubuntu 12.04 using ubuntuGIS Repository
>> On 07/09/2014 07:28 AM, Victor Olaya wrote:
>> No, it sounds like a bug, and someone else reported that to me yesterday
>> as well. It doens't happen in all installations of QGIS apparently. I will
>> try to work on that at the end of the day today.
>> Thanks for your help!
>> 2014-07-09 12:44 GMT+02:00 Jonathan Moules <
>>> Hi List,
>>> Using 2.4 I've noticed that on the "simplified toolbox" there aren't
>>> actually any tools any more.
>>> There are only Models and Scripts (neither of which is simple. And
>>> also "recently used", although that requires the user to have found the
>>> advanced interface.
>>> Is this intentional? I guess not given it seems pointless to have a
>>> "simplified interface" for a toolbox that has no tools.
>>> Cheers,
>>> Jonathan
>>> This transmission is intended for the named addressee(s) only and may
>>> contain confidential, sensitive or personal information and should be
>>> handled accordingly. Unless you are the named addressee (or authorised to
>>> receive it for the addressee) you may not copy or use it, or disclose it to
>>> anyone else. If you have received this transmission in error please notify
>>> the sender immediately. All email traffic sent to or from us, including
>>> without limitation all GCSX traffic, may be subject to recording and/or
>>> monitoring in accordance with relevant legislation.
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Qgis-user mailing listQgis-user at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/qgis-user
>> Randal Hale
>> North River Geographic Systems, Inchttp://www.northrivergeographic.com423.653.3611 rjhale at northrivergeographic.com
>> twitter:rjhalehttp://about.me/rjhale
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140710/d15e4245/attachment.html>
