[Qgis-user] QGIS Server - filtering a layer for display in QWC or get print request
Bernhard Ströbl
bernhard.stroebl at jena.de
Mon Jul 14 23:55:49 PDT 2014
Hi Carlos,
the filter parameter is described here [1], have never tried it myself,
though. I doubt you can use a filter parameter in the GetPrint request,
maybe you should try and if it does not work fill in a ticket (feature
request), as I think this is a logical enhancement.
Looking at QWC you can display a layer (with all its features) and you
can search a layer but there is currently no possibility to reduce the
features being displayed (and I am not sure, if it even should be
possible). What you can do is load the layer several times in your
project and set a filter on it in order to have a distinct layer for
every project location or use the theme switcher and create a project
for every location.
Bernhard
P.S. Glad you solved the other problem :-)
[1]
http://hub.qgis.org/projects/quantum-gis/wiki/QGIS_Server_Tutorial#FILTER-parameter
Am 15.07.2014 02:31, schrieb Carlos da Ponte:
> Hi Everyone,
> Has anyone worked out a way to pass a filter query to QGIS server via a URL
> (or otherwise) that will filter a specific layer of the QGIS project that
> could then be viewed via QWC or used in a print request? here is the
> scenario:
> I have a layer in a QGIS project that contains many Project locations When
> using the QWC to view the layer or the server to print the layer, I want to
> make sure the user can only see the Project location they are interested in
> as some times these Project Locations are in close proximity to one another.
> Thanks!
> Carlos
__________ Information from ESET Mail Security, version of virus signature database 10097 (20140715) __________
The message was checked by ESET Mail Security.
http://www.eset.com
