[Qgis-user] numbers to text in column
Carlos Cerdán
sig.upagu at gmail.com
Tue Jul 15 05:46:32 PDT 2014
Hi Simo:
1. Open attribute table and create new text field (A number field doesn't
can be changed directly into text).
2. Select by expression (number = 34522)
3 Open field calculator and select update field. Update the created field
text. Expression for this field is new value that you want "1-2 floors".
4. Do same job for another value.
Good luck
Carlos
2014-07-15 6:06 GMT-05:00 Simo Turunen <simo.v.turunen at gmail.com>:
> What are the steps, if you want to change numbers to text?
> In atrribute table I have a column, which have numbers in it "34522" and
> "34521".
> I want to change it that number "34522" is called for example "1-2 floors"
> or house and "34521" is called "3-n floors" or something else.
> I could easily write that text in it, but when I have over 100 000 rows,
> it could take a little time :)
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140715/f70de78b/attachment.html>
