[Qgis-user] Problems with RGB channels for jpg
Nicole Stoffels
stoffels at f2e.de
Thu Jul 17 00:23:55 PDT 2014
Dear Otto,
thanks for your help! In the settings the green channel was set to 0.
Following your advice I changed it to 2. Now it works.
Best wishes
Nicole
Am 17.07.2014 08:58, schrieb Otto Dassau:
> Dear Nicole,
> it might be a "problem" of your hardware and difficult to solve on the ml,
> if it only happens on your pc with the same layer. As a workaround for that
> file, you could create a .qml style file for the jpg file, after you changed
> the channel order to r,g,b as necessary. This lets QGIS load the file with
> the channel order you defined.
> Kind Regards
> Otto
> Am Fri, 11 Jul 2014 09:28:07 +0200
> schrieb Nicole Stoffels <stoffels at f2e.de>:
>> Dear all,
>> I seem to have a problem loading a jpg or other picture formats in QGIS.
>> If I drag and drop a jpg to QGIS, the green channel is not defined in
>> the properties which makes the jpg pink. I can add it manually in the
>> properties, but first the picture is pink by default. If my colleagues
>> load the same picture, they don't have this problem. There the red,
>> green and blue channel are found by QGIS.
>> I am using a QGIS 2.4 (same as my colleagues) but the problem already
>> occurred in my old QGIS version. Furthermore I am using an ubuntu 12.04
>> on 64 bit machine.
>> Did anybody ever hear of this problem or also had it himself?
>> Thanks for your help!
>> Best wishes
>> Nicole Stoffels
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
