[Qgis-user] R: Re: Marker Symbol
Andreas Neumann
a.neumann at carto.net
Thu Jul 24 05:00:52 PDT 2014
What exactly do you want to know? What part of the symbology or labeling?
The leader lines between the house-nr and the street axis was generated
by a SQL query in Postgis. I can forward you the SQL query if you are
interested in the leader lines.
The rest is just labeling in QGIS, with data-defined positioning and
rotation and a background rectangle that automatically rotates and
adapts the size according to the label - a builtin feature of the QGIS
labeling engine.
Andreas
Am 24.07.2014 11:43, schrieb labiancamarilena at libero.it:
> Hi,
> can you tell me how you produce that map by intranet?
> Thanks a lot
> Marilena
>> ----Messaggio originale----
>> Da: a.neumann at carto.net
>> Data: 24/07/2014 13.24
>> A: <qgis-user at lists.osgeo.org>
>> Ogg: Re: [Qgis-user] Marker Symbol
>> Hi Les,
>> Here is an example where I combine labels with a rectangular dynamic
>> background for a house-nr plan (rendered by QGIS server):
>> http://webgis.uster.ch/wsgi/webgisLauncher.wsgi?uuid=e4694012-39c9-4ad0-8494-
> 7e514911c7f3
>> Andreas
>> Am 24.07.2014 09:50, schrieb les at true3d.com.au:
>>> I am seeking assistance in creating a composite marker symbol for a
>>> point layer. I would like to create a rectangular point marker that
>>> contained the actual number of the point. The marker will be different
>>> for each point. Is this possible in QGIS 2.4 Chugiak.
>>> I would appreciate any assistance.
>>> Regards,
>>> Les Searle
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
