[Qgis-user] Qgis server returns map from another project, that is defined in URL
Jan Michálek
godzilalalala at gmail.com
Thu Jul 24 11:34:52 PDT 2014
Thanks
No, this problem is not in browser, becouse we had try it on more computers
in the same time. And I opened it in qgis (wms)...
Je;
2014-07-24 20:27 GMT+02:00 Alex Mandel <tech_dev at wildintellect.com>:
> On 07/24/2014 09:56 AM, Jan Michálek wrote:
> > Have a nice day
> > I have problem with qgis server (2.2). I have a few projects in my
> folders
> > and qgis doesn't use project specify in my url.
> > For example i had folder called
> > projects
> > with two files. red.qgs a green.qgs with the same layer (from postgis),
> but
> > with differenet symbology (fill color).
> > i use for first time url like this
> http://nejakejservr.cz/cgi-bin/qgis_mapserv.fcgi?MAP=/mnt/data/projects/red.qgs&REQUEST=GetMap&BBOX=-615170.147011,-1003827.798116,-614613.882202,-1003027.916641&CRS=EPSG:5514&WIDTH=400&HEIGHT=300&LAYERS=test&STYLES=,,&FORMAT=image/png&DPI=96
> > And I obtain red filled polygons (as is specified in red.qgs project).
> > If i use this.
> http://nejakejservr.cz/cgi-bin/qgis_mapserv.fcgi?MAP=/mnt/data/projects/green.qgs&REQUEST=GetMap&BBOX=-615170.147011,-1003827.798116,-614613.882202,-1003027.916641&CRS=EPSG:5514&WIDTH=400&HEIGHT=300&LAYERS=test&STYLES=,,&FORMAT=image/png&DPI=96
> > I should obtain layer from green.qgs project, but i obtain red filled
> > polygons from project i had use before.
> > I had use qgis (2.4) on my desktop for this wms, but with the same
> problem.
> > I get lazers from first used project.
> > Why?
> > How I can change this?
> > Thanks Je;
> Could it be your browser is caching the page since the url is the same
> and only the parameters are changing? Try clearing your cache and
> starting with the green url.
> Thanks,
> Alex
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140724/d2fab38e/attachment.html>
