[Qgis-user] Qgis server returns map from another project, that is defined in URL
Jan Michálek godzilalalala at gmail.com
Thu Jul 24 13:25:20 PDT 2014
Maybe is the problem in fact that i was creating this projects by cloning
one with using sed etc for changing database schemes etc tj. layer id are
the same in more projects.
2014-07-24 21:24 GMT+02:00 Jan Michálek <godzilalalala at gmail.com>:
> One more interesting thing, I'm able to select layers from wms, if they
> have the same names. Maybe is solution for me select unique name for all
> layers in my projects.
> 2014-07-24 20:34 GMT+02:00 Jan Michálek <godzilalalala at gmail.com>:
> Thanks
>> No, this problem is not in browser, becouse we had try it on more
>> computers in the same time. And I opened it in qgis (wms)...
>> Je;
>> 2014-07-24 20:27 GMT+02:00 Alex Mandel <tech_dev at wildintellect.com>:
>> On 07/24/2014 09:56 AM, Jan Michálek wrote:
>>> > Have a nice day
>>> > I have problem with qgis server (2.2). I have a few projects in my
>>> folders
>>> > and qgis doesn't use project specify in my url.
>>> > For example i had folder called
>>> > projects
>>> > with two files. red.qgs a green.qgs with the same layer (from
>>> postgis), but
>>> > with differenet symbology (fill color).
>>> > i use for first time url like this
>>> http://nejakejservr.cz/cgi-bin/qgis_mapserv.fcgi?MAP=/mnt/data/projects/red.qgs&REQUEST=GetMap&BBOX=-615170.147011,-1003827.798116,-614613.882202,-1003027.916641&CRS=EPSG:5514&WIDTH=400&HEIGHT=300&LAYERS=test&STYLES=,,&FORMAT=image/png&DPI=96
>>> > And I obtain red filled polygons (as is specified in red.qgs project).
>>> > If i use this.
>>> http://nejakejservr.cz/cgi-bin/qgis_mapserv.fcgi?MAP=/mnt/data/projects/green.qgs&REQUEST=GetMap&BBOX=-615170.147011,-1003827.798116,-614613.882202,-1003027.916641&CRS=EPSG:5514&WIDTH=400&HEIGHT=300&LAYERS=test&STYLES=,,&FORMAT=image/png&DPI=96
>>> > I should obtain layer from green.qgs project, but i obtain red filled
>>> > polygons from project i had use before.
>>> > I had use qgis (2.4) on my desktop for this wms, but with the same
>>> problem.
>>> > I get lazers from first used project.
>>> > Why?
>>> > How I can change this?
>>> > Thanks Je;
>>> Could it be your browser is caching the page since the url is the same
>>> and only the parameters are changing? Try clearing your cache and
>>> starting with the green url.
>>> Thanks,
>>> Alex
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140724/c1a988ca/attachment.html>
