[Qgis-user] Qgis server returns map from another project, that is defined in URL
Jan Michálek
godzilalalala at gmail.com
Thu Jul 24 13:30:55 PDT 2014
Yes, I changed layer id and everuthing works OK.
2014-07-24 22:27 GMT+02:00 Paolo Cavallini <cavallini at faunalia.it>:
> Exactly.
> Known bug, or limitation.
> On 24 luglio 2014 22:25:20 CEST, "Jan Michálek" <godzilalalala at gmail.com>
> wrote:
>> Maybe is the problem in fact that i was creating this projects by cloning
>> one with using sed etc for changing database schemes etc tj. layer id are
>> the same in more projects.
>> 2014-07-24 21:24 GMT+02:00 Jan Michálek <godzilalalala at gmail.com>:
>>> One more interesting thing, I'm able to select layers from wms, if they
>>> have the same names. Maybe is solution for me select unique name for all
>>> layers in my projects.
>>> 2014-07-24 20:34 GMT+02:00 Jan Michálek <godzilalalala at gmail.com>:
>>> Thanks
>>>> No, this problem is not in browser, becouse we had try it on more
>>>> computers in the same time. And I opened it in qgis (wms)...
>>>> Je;
>>>> 2014-07-24 20:27 GMT+02:00 Alex Mandel <tech_dev at wildintellect.com>:
>>>> On 07/24/2014 09:56 AM, Jan Michálek wrote:
>>>>> > Have a nice day
>>>>> > I have problem with qgis server (2.2). I have a few projects in my
>>>>> folders
>>>>> > and qgis doesn't use project specify in my url.
>>>>> > For example i had folder called
>>>>> > projects
>>>>> > with two files. red.qgs a green.qgs with the same layer (from
>>>>> postgis), but
>>>>> > with differenet symbology (fill color).
>>>>> > i use for first time url like this
>>>>> http://nejakejservr.cz/cgi-bin/qgis_mapserv.fcgi?MAP=/mnt/data/projects/red.qgs&REQUEST=GetMap&BBOX=-615170.147011,-1003827.798116,-614613.882202,-1003027.916641&CRS=EPSG:5514&WIDTH=400&HEIGHT=300&LAYERS=test&STYLES=,,&FORMAT=image/png&DPI=96
>>>>> > And I obtain red filled polygons (as is specified in red.qgs
>>>>> project).
>>>>> > If i use this.
>>>>> http://nejakejservr.cz/cgi-bin/qgis_mapserv.fcgi?MAP=/mnt/data/projects/green.qgs&REQUEST=GetMap&BBOX=-615170.147011,-1003827.798116,-614613.882202,-1003027.916641&CRS=EPSG:5514&WIDTH=400&HEIGHT=300&LAYERS=test&STYLES=,,&FORMAT=image/png&DPI=96
>>>>> > I should obtain layer from green.qgs project, but i obtain red filled
>>>>> > polygons from project i had use before.
>>>>> > I had use qgis (2.4) on my desktop for this wms, but with the same
>>>>> problem.
>>>>> > I get lazers from first used project.
>>>>> > Why?
>>>>> > How I can change this?
>>>>> > Thanks Je;
>>>>> Could it be your browser is caching the page since the url is the same
>>>>> and only the parameters are changing? Try clearing your cache and
>>>>> starting with the green url.
>>>>> Thanks,
>>>>> Alex
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
> http://faunalia.eu/
> Sent from mobile, sorry for being short
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140724/8e0f5e14/attachment.html>
