[Qgis-user] (no subject) - Compressing Raster
Alex Mandel
tech_dev at wildintellect.com
Tue Jul 29 10:39:00 PDT 2014
On 07/29/2014 10:31 AM, Etienne Tourigny wrote:
> On Tue, Jul 29, 2014 at 1:10 PM, Alex Mandel <tech_dev at wildintellect.com>
> wrote:
>> On 07/29/2014 01:45 AM, Peter Versteeg wrote:
>>> thank you very much for the email.
>>> I think I am almost there. I have set the compression to LZW and did a
>>> export and I did a export on high compression. Both are still really big.
>>> in your first mail you explained about:
>>> The type of number stored dictates a large amount of
>> overhead,
>>> there is
>>> a huge difference between Integer and Float.
>>> -co COMPRESS=LZW -ot Int16
>>> See http://www.gdal.org/gdal_translate.html for options.
>>> Pick the
>>> smallest type of number storage that holds your data
>>> correctly. Most
>>> GDAL tools will default to Float, that is likely the
>>> difference.
>>> In the save raster as window where i also set the compress to LZW i did
>> try
>>> to ad a line but i do not know what to type.
>>> name: Int value 16 or name ot value int16 all do not work.
>>> Can you tell me what line to write
>>> gr Peter
>> As I said in my previous email:
>> If that still isn't enough use GDAL Translate found on the Raster menu
>> under Conversion. There you will be able to set all the possible options.
>> Basically the options are not in the Save As dialog. I will talk to the
>> developers about adding more options.
> You can do pretty much the same things as in the GDAL Translate tool - see
> the "Creation Options" group box. What is missing exactly?
-ot is missing, which lets you set the number type int/float etc
I have not tested if the save as dialog allows this, I was guessing that
only -co options were allowed in the Create Options section. -ot is not
a -co option, its a separate flag for gdal.
Thanks,
Alex
