[Qgis-user] Problems with SAGA modules
Luis Miguel Royo Pérez
luis.miguel.royo at gmail.com
Wed Jul 30 10:20:02 PDT 2014
Hi everyone,
I'm getting some errors trying to execute a SAGA module "spatial point
pattern analysis". When I try to run it, stops and the QGIS log says this:
La fuente de datos no es válida ()
The log of the processor don't say too much:
SAGA execution console output
_____________________________________________
library path: /usr/lib/i386-linux-gnu/saga/libshapes_polygons.so
library name: Shapes - Polygons
tool name : Polygon Centroids
author : (c) 2003 by O.Conrad
Load shapes:
/home/luismi/.qgis2/python/plugins/processing/tests/data/polygons.shp...
Parameters
Polygons: polygons
Centroids: Centroids
Centroids for each part: no
Save shapes:
/tmp/processing/2bdf3110e8ef480c8e7018eabc704571/CENTROIDS.shp...
I don't know if this log message is related, but this library is not
being loaded.
No se pudo cargar /usr/lib/qgis/plugins/libglobeplugin.so (motivo:
Cannot load library /usr/lib/qgis/plugins/libglobeplugin.so:
(libosgEarth.so.1: no se puede abrir el archivo del objeto compartido:
No existe el archivo o el directorio))
On the other side it happens the same when I try to execute the GRASS
algorithm r.drain in the processor.
I'm using QGIS 2.4, on Ubuntu 12.04.
Thanks to everyone.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140730/c8f84a48/attachment.html>
