[Qgis-user] GPS issue on android tablet
Michael.Dodd
michael.dodd at open.ac.uk
Wed Jun 4 07:21:31 PDT 2014
I would echo Mike's comments here.
You could try the google background imagery, in a few places in UK where I have checked their error is around 2m or better although in some places it can be a lot worse than this so it depends where you are as to how reliable this imagery is.
'Professional level' dgps can often give 1-2cm accuracy in real time using correction services such as Smartnet (in UK and parts of Europe) but the kit is expensive and you have to pay a license to use the correction service.
Mike
________________________________________
Sent: Wednesday, June 04, 2014 10:36 AM
To: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] GPS issue on android tablet
Zoltan,
I suggest you create a Csv file and plot the points on a large scale map
or hi-res satellite image.
You say "varies very widely", a quick check indicated the max. variation
between your points is approx 8m and the min. approx 1m.
I would say if you are getting 3m GPS accuracy that is pretty good if
you are outside the US or Europe. I assume you are using a dedicated
GPS unit attached to your Tablet and not a built-in GPS on your Tablet.
Bear in mind that the 3m accuracy deviation (imagine a 3m radius circle
from where you mark the point) can be in any direction, so if you are 3m
E out with first reading and 3m W with the second reading the error
between the point could be 6m.
Mike
On 04/06/2014 10:14, Zoltan Szecsei wrote:
> On 2014/06/04 11:07, Giuseppe De Marco wrote:
>> hello, I've been using Qgis on android tablet (samsung galaxy tab 2)
>> and I've been experimenting GPS connection.
>> The issue is that even if Qgis finds and use several satellites (9 or more)
>> precision never gets under 3.0 meters but what is strange is that
>> coordinates value fro the same spot varies very widely:
>> Time Coordinates Altitude
>> 14:39:36 41.69528959 13.26464738 343.1
>> 14:39:54 41.69529880 13.26466761 341.8
>> 14:40:06 41.69528519 13.26470222 340.4
>> 14:41:18 41.69528944 13.26472418 341.1
>> 14:41:42 41.69529608 13.26471821 341.8
>> 14:41:54 41.69530621 13.26470892 342.5
>> I have colleagues who have experienced the same.
>> Has anyone else experienced the same issue?
>> Is that depending on GPS device or could it be a software related
>> issue?
> There are probably 10000 reasons for this.
> I am surprised that you even think you are getting sub 5m accuracy.
> Please plot the points on a cadastral map (or some basemap that is
> "guaranteed" accurate) and see what you are really getting.
> You also don't say whether you are in a tree'd or urban (or whatever)
> area - but observing 9 satellites suggests somewhere in the open.
> For professional GPSes, to get sub 10cm accuracy, you need to observe
> for 30-60 minutes, and do post processing.
> I am not a surveyor, so my info may be not 100% - Please can a surveyor
> or someone well experienced in these issues chip in.
> Regards,
> Zoltan
Qgis-user mailing list
Qgis-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-user
-- The Open University is incorporated by Royal Charter (RC 000391), an exempt charity in England & Wales and a charity registered in Scotland (SC 038302). The Open University is authorised and regulated by the Financial Conduct Authority.
