[Qgis-user] Problem with features selection
    Ourizo Cacho
    usuario7 at gmx.es
    Tue Jun 10 04:17:35 PDT 2014
Yes, it´s a solution, thanks.
I was only thinking of a direct way and your two-steps workaround is
nice too.
Thank you!
El 10/06/2014 12:52, Joachim Józefowicz escribió:
> You can build a model with a geoprocessing.
> First built buffer around your rivers with qgis algorithm fixed
> distance buffer then select by location your gas station with qgis
> algorithm Select by location.
> Thats all.
> 2014-06-10 11:38 GMT+02:00 Ourizo Cacho <usuario7 at gmx.es
> <mailto:usuario7 at gmx.es>>:
>     Hello everyone,
>     I have two vectorial shapes: Gas Stations (points) and rivers (lines).
>     I want to select those points which are less than 300 meters far
>     from the rivers, and I cant figure out how to do this with QGIS.
>     I tried with Spatial Query but no chance with it. So I thought of
>     a selection with an expression and the funtion Geometry. I´ve made
>     several trials but no way. I can´t find an expression with a valid
>     sintaxys.
>     How can I do this with QGIS??. Do I need to install some plugin??.
>     Thanks beforehand.
>     Este mensaje no contiene virus ni malware porque la protección de
>     avast! Antivirus está activa.
>     http://www.avast.com
>     _______________________________________________
>     Qgis-user mailing list
>     Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>     http://lists.osgeo.org/mailman/listinfo/qgis-user
Este mensaje no contiene virus ni malware porque la protección de avast! Antivirus está activa.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140610/e4385ba4/attachment.html>
