[Qgis-user] LIZMAP ERROR PRINT - HELP!
kimaidou
kimaidou at gmail.com
Tue Jun 10 08:32:35 PDT 2014
Hi Andrea,
This must be a QGIS Server error, as Lizmap only build the GetPrint url and
send it to QGIS Server.
Could you please be more explicit with the encountered error ? Do you have
any log in the Apache error log ? (usually in /var/log/apache2/error.log if
you have not changed the default value ).
What is the content of the composer you try to print via the GetPrint
request ? Does it contains any HTML items, or text items with "display
HTML" ?
Thanks for your answer,
Michael
2014-06-10 13:05 GMT+02:00 Andrea Fantini <afantini at gmail.com>:
> Hello
> I developed a WebGIS with lizmap 2.10 but I have a problem with the print
> button is Lizmap with version 2.8, 2.9 to 2.10, that is, when I click on
> the print button I generate a pdf white. For me it works all the rest.
> This problem is also present with the demo present by default in all
> versions of lizmap.
> My server is Debian version 7.5, this is the package x11-common and also I
> also followed this guide:
> http://www.itopen.it/2014/03/13/qgis-server-setup-notes/lang-pref/en/ ,
> but unfortunately the problem remains.
> The project has been realized with Qgis 2.2.
> Thank you very much for your support!
> BY
> Andrea
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140610/0191ec30/attachment.html>
