[Qgis-user] Problems with date fields from Postgis + QGIS
McDonaldR
McDonaldR at angus.gov.uk
Tue Jun 10 08:44:07 PDT 2014
Hi Jürgen,
It works with ae9048a (build 107 from OSGeo4W). A NULL value is correctly updated in the table, as is a valid date.
What is odd is, if you set the date field edit widget to LINE EDIT then the field is populated with a NULL by default (or a date if you enter a date string). However, if you set the edit widget to a DATE/TIME widget then the field is automatically populated with today's date. If you don't touch the field then it is populated with a NULL when you commit the change but if you open the calendar popup or use the arrows to change the date then the field is updated with the value selected.
Is this the default behaviour? Is this the Qt defined behaviour of the date widget?
Ross
-----Original Message-----
From: qgis-user-bounces at lists.osgeo.org [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Jürgen E. Fischer
Sent: 09 June 2014 20:55
To: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] Problems with date fields from Postgis + QGIS
Hi Ross,
On Mon, 09. Jun 2014 at 19:49:01 +0100, Ross McDonald wrote:
> I found this in the issues list: http://hub.qgis.org/issues/988
> Seems to have been around before although there is no fix outlined here.
Please verify if e605ad65 solves it.
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
QGIS PSC member (RM) Germany IRC: jef on FreeNode
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
Qgis-user mailing list
Qgis-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-user
This message is strictly confidential. If you have received this in error, please inform the sender and remove it from your system. If received in error you may not copy, print, forward or use it or any attachment in any way. This message is not capable of creating a legal contract or a binding representation and does not represent the views of Angus Council. Emails may be monitored for security and network management reasons. Messages containing inappropriate content may be intercepted. Angus Council does not accept any liability for any harm that may be caused to the recipient system or data on it by this message or any attachment.
