[Qgis-user] Linux build
David J. Bakeman
dbakeman at comcast.net
Wed Jun 11 14:42:45 PDT 2014
On 06/11/2014 02:20 PM, Volker Fröhlich wrote:
> Am 2014-06-11 23:15, schrieb Volker Fröhlich:
>> Am 2014-06-11 22:41, schrieb David J. Bakeman:
>>> I am running qgis on a Fedora core 18 laptop. I run both the packcaged
>>> qgis 1.8 and I build the development version. Recently I wanted to use
>>> spatialite version 4.1.1 instead of the 3.1 version packaged with
>>> Fedora. I successfully built both sqlite 3.8 and Spatialite 4.1.1. I
>>> built static libraries to avoid accidentally picking up the system
>>> shared libraries. When I tried to configure qgis to use the new
>>> libraries by changing the paths
>>> SPATIALITE_INCLUDE_DIR/SPATIALITE_LIBRARY/SQLITE3_INCLUDE_DIR/SQLITE3_LIBRARY
>>> but this didn't work. The only way I was able to get it to work was to
>>> modify the FindSPATIALITE.cmake script to the skip the library check
>>> and
>>> to add -DSPATIALITE_VERSION_GE_4_0_0 to the CMAKE_CXX_FLAGS.
>>> My question is should I have been able to just adjust the
>>> spatialite/sqlite variables or is the way I did it the only way?
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Fedora 18 is out of maintenance! :)
>> Fedora 20 has 2.2. Will that do?
>> Volker
> Wait, Fedora 20 actually has 2.0. I was afraid to push 2.2 because of
> some issues when opening 2.0 projects. However, you can install 2.2 in
> Fedora 20: yum --enablerepo=updates-testing install qgis-whatever
Unfortunately I'm stuck with 18 for awhile anyway. As I said I was able
to build but modifying the cmake script seems bad and I assumed there
was a better way.
What version of spatialite goes with 20?
> Volker
