[Qgis-user] TAB file export
Bo Victor Thomsen bo.victor.thomsen at gmail.com
Wed Jun 11 21:05:56 PDT 2014
Brett -
I've opened your shape file in QGIS and afterwards saved it as a tab
file - without a hitch. I'm using a newish version 2.3 of QGIS.
I've opened the new tab file in MapInfo and it works. The only strange
thing is, that the projection shifts from EPSG:28351 to EPSG:32751
Tabfile attached
Regards
Bo Victor Thomsen
Aestas-GIS
Denmark
Den 12-06-2014 03:03, Brett Adams skrev:
> Zoltan,
> I'm running the ogr2ogr using ogr2gui.  Is that cheating?  I get in trouble
> with command line stuff.
> I can export a mid/mif, works perfectly every time.  It's just not what the
> client wants.  I've attached a sample SHP file. It was created by importing
> a CSV file then exporting as a SHP file.
> Donovan,
> I ran  : Vector > Geometry Tools > Check Geometry Validity     but came up
> with no errors.
> Couldn't find the "Topology Checker" plugin.  Is that a version 2 feature?
> Thanks your feedback.  I appreciate the effort.
> Brett
> -----Original Message-----
> From: qgis-user-bounces at lists.osgeo.org
> [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Saulteau Don
> Sent: Thursday, 12 June 2014 3:53 AM
> To: qgis-user at lists.osgeo.org
> Subject: Re: [Qgis-user] TAB file export
>>> Ross
>>> On 11/06/14 06:23, Brett Adams wrote:
>>>      I keep getting  an error
>>>      Export to vector file failed.
>>>      Error: Feature write errors:
>>>      Feature creation error (OGR error: Failed writing geometry for
>>>      feature id 1 in
> I usually get that error when some of the shapefile features are "invalid".
> Did you get a chance to check for validity of the features in the shapefile?
> In QGIS you can use the "Topology Checker" plugin.
> Or Vector > Geometry Tools > Check Geometry Validity.
> Donovan
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140612/3c1c0134/attachment.html>
Type: application/zip
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140612/3c1c0134/attachment.zip>
