[Qgis-user] Error with QGIS Server on Debian wheezy
Marco Hugentobler
marco.hugentobler at sourcepole.ch
Thu Jun 12 00:20:44 PDT 2014
Hi
The server normally detects the relative path and expands it to an
absolute one internally.
I just tested a project with relative pathes containing a shape and a
spatialite layer and it worked fine here (tested with QGIS 2.2 / current
master / Enterprise worked in all cases).
Regards,
Marco
On 11.06.2014 09:48, Zedler, Jörg (regio iT) wrote:
> Hi,
> I have found an explanation for my problem:
> Although in my project the path to Shape-File is stored relative, QGIS
> Server interpreted the path as an absolute path.
> Example out of the project file:
> <datasource>./TestShape.shp</datasource>
> Therefore the shape file is not found.
> With an symbolic link in root-directory, everything works.
> Is this problem known?
> Is there any better workaround?
> Thanks,
> J. Zedler
> *Von:*qgis-user-bounces at lists.osgeo.org
> [mailto:qgis-user-bounces at lists.osgeo.org] *Im Auftrag von *Zedler,
> Jörg (regio iT)
> *Gesendet:* Donnerstag, 5. Juni 2014 21:07
> *An:* qgis-user at lists.osgeo.org
> *Betreff:* [Qgis-user] Error with QGIS Server on Debian wheezy
> Hi,
> I need some help, running QGIS Server 2.2.0 on Debian wheezy.
> Using QGIS-Projects with Datasource Postgres works fine.
> Using QGIS-Projects with Datasource Shape-File didn't work.
> The same Project on Windows (also QGIS Server 2.2.0) works.
> GetCapabilities-Request gives all but no info for Shape-Layers
> Output on stderr: ERROR 10: Pointer 'hDS' is NULL in 'OGR_DS_Destroy'
> GetMap-Request crashes with Segmentation fault
> The Debian-Server is installed without X-Server Packages.
> Is there any idea, what's going wrong?
> Regards
> J. Zedler
> Qgis-user mailing list
Dr. Marco Hugentobler
Sourcepole - Linux & Open Source Solutions
Weberstrasse 5, CH-8004 Zürich, Switzerland
marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
Technical Advisor QGIS Project Steering Committee
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140612/f41a6d55/attachment.html>
