[Qgis-user] TAB file export
Zoltan Szecsei
zoltans at geograph.co.za
Thu Jun 12 01:15:29 PDT 2014
Hi Brett,
If you can create MID/MIF, just open the mid file in a text editor and
check that the number of lines is the same as the number of features in
your shapefile.
If yes, then you should have all your elements.
Then simply convert the MID/MIF to TAB
It's a 2-step solution, but it should get the job done.
On the other post regarding the changing EPSG code, check the beginning
of your MIF file to see if it is "wrong" there already (MIF is also a
text file)
If so, it may be BUG-reporting time.
I am assuming that your shapefile has a PRJ file, or in QGIS you have
set the correct projection/CRS
HTH,
Zoltan
On 2014/06/12 03:03, Brett Adams wrote:
> Zoltan,
> I'm running the ogr2ogr using ogr2gui. Is that cheating? I get in trouble
> with command line stuff.
> I can export a mid/mif, works perfectly every time. It's just not what the
> client wants. I've attached a sample SHP file. It was created by importing
> a CSV file then exporting as a SHP file.
> Donovan,
> I ran : Vector > Geometry Tools > Check Geometry Validity but came up
> with no errors.
> Couldn't find the "Topology Checker" plugin. Is that a version 2 feature?
> Thanks your feedback. I appreciate the effort.
> Brett
> -----Original Message-----
> From: qgis-user-bounces at lists.osgeo.org
> [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Saulteau Don
> Sent: Thursday, 12 June 2014 3:53 AM
> To: qgis-user at lists.osgeo.org
> Subject: Re: [Qgis-user] TAB file export
>>> Ross
>>> On 11/06/14 06:23, Brett Adams wrote:
>>> I keep getting an error
>>> Export to vector file failed.
>>> Error: Feature write errors:
>>> Feature creation error (OGR error: Failed writing geometry for
>>> feature id 1 in
> I usually get that error when some of the shapefile features are "invalid".
> Did you get a chance to check for validity of the features in the shapefile?
> In QGIS you can use the "Topology Checker" plugin.
> Or Vector > Geometry Tools > Check Geometry Validity.
> Donovan
> Qgis-user mailing list
Zoltan Szecsei PrGISc [PGP0031]
Geograph (Pty) Ltd.
GIS and Photogrammetric Services
P.O. Box 7, Muizenberg 7950, South Africa.
Mobile: +27-83-6004028
Fax: +27-86-6115323 www.geograph.co.za
