[Qgis-user] Problem updating qgis-dev
Alexandre Neto
senhor.neto at gmail.com
Thu Jun 12 01:37:40 PDT 2014
Hello,
I have regular internet connection problems, therefore incomplete downloads
were making my qgis-dev daily update process miserable...
I found out a workaround tho.
I use wget do directly download the qgis-dev package (that preforms resumes
in case of internet connection is lost):
http://download.osgeo.org/osgeo4w/x86_64/release/qgis/qgis-dev/
And copy it to my temporary files instalation folder (normally with a name
like http%3a%2f%2fdownload.osgeo.org%2fosgeo4w), inside the respective
subfolder
After that I run osgeo4w-setup.exe choosing install from internet. Since
the package is already there the installer just checks it's integrity and
install it.
Hope this helps,
Alexandre Neto
On Wed, Jun 11, 2014 at 6:39 PM, Goyo <goyodiaz at gmail.com> wrote:
> 2014-06-10 10:50 GMT+02:00 Andrea Peri <aperi2007 at gmail.com>:
> > Hi,
> > Actually I'm work often with qgis-dev to try to test the last version.
> > Just now I try to update it using the osgeo4w.
> > I work behind a proxy.
> > Usually ths update wor well without any problem.
> > Just now instead, whaen I do the download.
> > It report download incomplete.
> > I do OK and it start removing my actual qgis-dev version.
> > But because the download was incomplete after the remove phase all stop.
> > And now I have no more qgis-dev.
> Hello Andrea, I have seen this before at my workplace, usually with
> grass packages. Downgrading to the previous version used to work since
> it was kept in the download directory.
> Goyo
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140612/fe4f26cf/attachment.html>
