[Qgis-user] Adding Projections
Richard McDonnell
richard.mcdonnell at opw.ie
Thu Jun 12 07:52:07 PDT 2014
Ok, I am open to correction, but you can use Custom CRS under Settings
1. Click add new CRS
2. Give it a name
3. I done a search online for POSGAR2007 and came across this page
http://spatialreference.org/ref/sr-org/posgar-2007-argentina-2/
4. If you select PROJ4 copy the text and paste it into the Parameters
box in Custom CRS
5. You can do a test then at the bottom, inputting the WGS84
coordinates for a known point and press calculate, if the points
match then you are in business!!
Regards,
Richard.
On 12/06/2014 14:57, Werner Horsch wrote:
> I'm running QGIS 2.0.1 Dufour on Linux
> Â
> I'd like to have POSGAR2007 "Argentina" Projection added on the
> projection list, can someone give me a hint on this
> Thanks
> Qgis-user mailing list
Email Disclaimer: http://www.opw.ie/en/disclaimer/
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140612/a4935a22/attachment.html>
Type: text/x-vcard
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140612/a4935a22/attachment.vcf>
