[Qgis-user] TAB file export - Solved
    Brett Adams
    badams at spinifexgeophysics.com.au
    Thu Jun 12 18:16:32 PDT 2014
Thanks Ramon.
Removed the spaces from the field names and the export worked perfectly.
The projection shifts from EPSG:28351 to EPSG:32751
Re: The projection change EPSG:28351 (GDA94/MGA-zone51) to EPSG:32751(WGS84
UTM zone 51S). These are essentially identical projections, possibly cross
referenced in projection definitions or just copied.
Exporting MID/MIF files or upgrading to 2.3 allows the spaces in the field
names.
Thanks everyone.
Brett
-----Original Message-----
[mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of custard
Sent: Thursday, 12 June 2014 8:39 PM
To: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] TAB file export
On 12/06/14 09:03, Brett Adams wrote:
> Zoltan,
> I'm running the ogr2ogr using ogr2gui.  Is that cheating?  I get in
> trouble with command line stuff.
> I can export a mid/mif, works perfectly every time.  It's just not
> what the client wants.  I've attached a sample SHP file. It was
> created by importing a CSV file then exporting as a SHP file.
> Donovan,
> I ran  : Vector > Geometry Tools > Check Geometry Validity     but came up
> with no errors.
> Couldn't find the "Topology Checker" plugin.  Is that a version 2 feature?
> Thanks your feedback.  I appreciate the effort.
> Brett
Hi Brett,
I suspect it's the spaces in the field names...
-ramon.
Qgis-user mailing list
Qgis-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-user
