[Qgis-user] How often is rebuilt qgis-dev in OSGeo4W?
Junior Delaz
delazj at gmail.com
Fri Jun 13 12:26:35 PDT 2014
Finally, i downloaded osgeo4w-setup-x86.exe and when i ran it, it
proposed *2.3.0-111.
A*ll is ok, now.
Furthermore, i remarked that my old install file is osgeo4w-setup.exe
(without the x86). After i updated qgis-dev, i ran once again my old exe.
It still proposes 2.3.0.97 as new release although it displays 2.3.0.111 as
current release. Strange...
2014-06-13 20:29 GMT+02:00 Junior Delaz <delazj at gmail.com>:
> I have the same information in x86-64
> I just download once again the release in x86. This is what I get in the
> setup.ini file:
> @ qgis-dev
> sdesc: "QGIS nightly build of the master"
> ldesc: "QGIS nightly build of the master"
> category: Desktop
> requires: msvcrt qt4-libs libpq gsl-libs proj geos gdal gdal-python
> spatialite zlib grass python-core sip pyqt4 qwt5-libs-qt4 iconv fcgi
> libspatialindex psycopg2 osgearth-libs python-qscintilla oci python-jinja2
> python-markupsafe python-pygments python-dateutil python-pytz
> version:* 2.3.0-97*
> install: ./release/qgis/qgis-dev/qgis-dev-2.3.0-97.tar.bz2 33331022
> dac4c73181ebd655e351fa9f06647b8f
> [prev]
> version: *2.3.0-95*
> install: ./release/qgis/qgis-dev/qgis-dev-2.3.0-95.tar.bz2 33398083
> 8eb327ed726f5cecc48799d6a42b9bad
> Any idea?
> 2014-06-13 16:32 GMT+02:00 Jürgen E. <jef at norbit.de>:
> Hi Junior,
>> On Fri, 13. Jun 2014 at 16:06:48 +0200, Junior Delaz wrote:
>> > Sorry but I d'on't really understand what i might look at in the .ini
>> link
>> > you sent.
>> It lists all installable packages. Currently for the qgis-dev package:
>> @ qgis-dev
>> category: Desktop
>> python-markupsafe pygments python-dateutil pytz
>> version: 2.3.0-100
>> install: x86_64/release/qgis/qgis-dev/qgis-dev-2.3.0-100.tar.bz2 38534980
>> 413bdd4f4c6a0af959237cd1befc60fe
>> [prev]
>> version: 2.3.0-98
>> install: x86_64/release/qgis/qgis-dev/qgis-dev-2.3.0-98.tar.bz2 38490399
>> 774088d3efeff6915e1d731f33faa7f1
>> So you should see 2.3.0-100 in the installer and you have the option to
>> alternatively go back to the previous one at 2.3.0-98. If your setup.ini
>> looks
>> different it's old.
>> Jürgen
>> Jürgen E. Fischer norBIT GmbH Tel.
>> +49-4931-918175-31
>> Dipl.-Inf. (FH) Rheinstraße 13 Fax.
>> +49-4931-918175-50
>> Software Engineer D-26506 Norden
>> http://www.norbit.de
>> QGIS PSC member (RM) Germany IRC: jef on
>> FreeNode
>> norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
>> Rheinstrasse 13, 26506 Norden
>> GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140613/49b32b17/attachment.html>
