[Qgis-user] Unable to open OGR .vrt file
Andrea Acinelli
aacinelli at gmail.com
Fri Jun 20 18:26:11 PDT 2014
Thanks Andre. Your help is very much appreciated.
Your last comment:
> Maybe there is another typo in your dataset. Alternatively, you can try
> ogr2ogr Global_24h.shp Global_24h.vrt
> and see if that shows the points correctly.
I tried the ogr2ogr utility that came with PostGIS by Postgresql.app and the resulting shapefile loads correctly in QGIS. The .vrt file I converted is the unedited one (see below) without the relativeToVRT="1" and reportSrcColumn="false" attributes:
<OGRVRTDataSource>
<OGRVRTLayer name="Global_24h">
<SrcDataSource>Global_24h.csv</SrcDataSource>
<GeometryType>wkbPoint</GeometryType>
<LayerSRS>EPSG:4326</LayerSRS>
<GeometryField encoding="PointFromColumns" x="longitude" y="latitude"/>
</OGRVRTLayer>
</OGRVRTDataSource>
The virtual file above seems to load correctly on windows as in your case. Can I ask other mac users to test the above .vrt file, the .csv can be downloaded from http://firms.modaps.eosdis.nasa.gov/active_fire/text/Global_24h.csv and see if they need to insert the additional attributes display the points?
Thanks
Andrea
NOTE: This is my first support request and I noticed that I didn't reply properly. Almost all my mails represent a new thread. How do I replay so that my replays appear indented from the previous post etc..
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140621/a61a5ec5/attachment.html>
