[Qgis-user] QGIS - gdal
Paulo van Breugel
p.vanbreugel at gmail.com
Mon Mar 3 02:41:41 PST 2014
Hi I am running QGIS master on Ubuntu 13.10. All runs fine, except for
any function that relies on gdal (raster menu or the gdal functions in
the processing toolbox). The functions work without problem on the
command line, but QGIS cannot find gdal it seems.
I compiled QGIS with the following gdal settings:
* GDAL_CONFIG = /usr/local/gdal1.10/bin/gdal-config
* GDAL_CONFIG_PREFER_FWTOOLS_PATH = /bin_safe
* GDAL_CONFIG_PREFER_PATH = /bin
* GDAL_INCLUDE_DIR = /usr/local/gdal1.10/include
* GDAL_LIBRARY = /usr/local/gdal1.10/lib/libgdal.so
I am actually not sure about the 2nd and 3rd. Are those settings correct?
I compiled gdal 1.10 from source in /usr/local/gdal and tried all the
following:
* added a gdal.conf file with the gdal lib path in the
etc/ld.so.conf.d folder (ran ldconfig)
* created a softlink of the usr/local/gdal1.10/bin folder in /usr/bin
* defined gdal paths in /home/paulo/.bashrc by adding the line: export
PATH=$PATH:/usr/local/gdal1.10/bin
* created executable file libraries.sh in /etc/profile.d with the lines
o #!/bin/sh
o LD_LIBRARY_PATH="$LD_LIBRARY_PATH:/lib:/usr/local/lib:/usr/local/gdal1.10/lib"
o export LD_LIBRARY_PATH
Any idea what to do next?
Paulo
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140303/e80c966d/attachment.html>
