[Qgis-user] Categorizing symbols with file geodatabase
    Randal Hale
    rjhale at northrivergeographic.com
    Tue Mar  4 07:37:51 PST 2014
/this might be a dupe - I finally exceeded the message size limits. /
Kristen - I did a test this morning using a file based geodatabase. I
built one with subtypes and that appears to mimic what you are
seeing...maybe.....Is the field that you are attempting to symbolize an
integer of some sort?
Do you have arcgis handy (I do and can check if you wish)? Can you
check? Right click the Feature class in Arc Catalog and click on the
subtypes tab.
Randy
> Randal Hale, GISP
> North River Geographic Systems, Inc
> http://www.northrivergeographic.com
> 423.653.3611rjhale at northrivergeographic.com
> twitter:rjhale
> http://about.me/rjhale
> On 03/03/2014 09:14 PM, Eric Goddard wrote:
>> Hi Kristen,
>> I'm a little confused with the terminology -- When you say only the
>> first field is recognized, are you referring to the first attribute
>> column? If you click the 'column' dropdown in the style settings
>> dialog, are there other fields to base the categorization on?
>> On Mon, Mar 3, 2014 at 5:08 PM, Kristen Klaphake
>> <kklaphake at west-inc.com <mailto:kklaphake at west-inc.com>> wrote:
>>     I don't have domains assigned in the geodatabase, so this
>>     shouldn't be the issue. It looks like it only recognizes the
>>     first field in the dataset when QGIS is categorizing the data for
>>     shading.
>>     On Mon, Mar 3, 2014 at 2:08 PM, Eric Goddard
>>     <egoddard1010 at gmail.com <mailto:egoddard1010 at gmail.com>> wrote:
>>         Hi Kristen and Randal,
>>         I think Randal is correct. There area a few issues preventing
>>         the equivalent of domains from working in QGIS, but the main
>>         issue is that QGIS uses GDAL to load vector data. GDAL has no
>>         concept of domains as far as I know. QGIS does somewhat--you
>>         can define value-description pairs that will show up in the
>>         attribute table from the layer properties.
>>         I just tested whether setting an attribute's edit widget
>>         (under Properties -> Fields) to value map and providing the
>>         value-description pairs there would allow them to be applied
>>         to symbology -- but it didn't work. If you have the
>>         descriptors for each category, they can be manually typed
>>         into the label. It isn't a great solution. :( Tests were
>>         performed with QGIS master 64bit, FileGDB API 1.3 on linux.
>>         Also, you may want to check your data to make sure all the
>>         values are showing up. When I was testing, only 1 category
>>         would appear when the attribute was classified from the file
>>         geodatabase feature class. When exported out to a shapefile,
>>         all of the unique values for that attribute would be listed.
>>         Eric
>>         On Mon, Mar 3, 2014 at 11:46 AM, Randal Hale
>>         <rjhale at northrivergeographic.com
>>         <mailto:rjhale at northrivergeographic.com>> wrote:
>>             First thought is your are working with a field that is a
>>             domain. Example being the values are 1 2 3 but in ArcGIS
>>             they are displayed as meaningful attributes
>>             Name Field - Domain
>>             1                     Randy
>>             2                     Kristen
>>             3                     Nathan
>>             BUT - you appear to be doing it right! But that doesn't
>>             help the value problem you are seeing.
>>             Randy
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140304/d4b19c0e/attachment.html>
