[Qgis-user] QGis 2.0.1 (german version): Transect with square	polygons
    Alexandre Neto
    senhor.neto at gmail.com
    Wed Mar  5 08:43:43 PST 2014
On Tue, Mar 4, 2014 at 2:48 PM, Daniel88 <d.weinberg at posteo.de> wrote:
> So far I know only the corresponding functions in ArcMap from ESRI. QGis
> seems equipped in the basic version with less features.
If you look carefully you see that qgis has many features that in ArcGIS
are only available in (very well) payed extentions. You just need to know
where to find them.
>  Although I have the
> plugin " Rectangles ovals digitizing " installed, but can not choose here
> the edge length . In addition, the following square is to connect
> seamlessly
For me, the fastest way to do this would be to use Andreas suggestion, the
Vector Grid, to create the the necessary number of squares (Polygons), say
18 x 2.
Like Andre said, they will be aligned with the coordinate system and not
with your working area. But that is not a problem, cause you can edit the
layer, select the desired squares, and use Rotate feature and move feature
in the digitizing toolbar to align and put the squares over your working
area.
Alexandre Neto
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140305/b5df8346/attachment.html>
