[Qgis-user] Beginner: How to find duplicate points with the Topology Checker plug-in
Jonathan Moules
jonathanmoules at warwickshire.gov.uk
Mon Mar 10 07:17:47 PDT 2014
Hi Robert,
There's also the SAGA extension which has a "Remove duplicate Points" tool.
Open the processing toolbox and set t to advanced interface and search for
"Duplicate" should find it.
Hopefully that'll work for you.
Cheers,
Jonathan
On 7 March 2014 12:48, Robert Harris <harris_robert at windstream.net> wrote:
> Hello All,
> I am a beginner using 2.0.1-Dufour on Ubuntu 12.04.
> I digitized a poly line into a shapefile that represents a water feature.
> I used Vector/Extract Nodes to create a point shapefile. I added fields to
> the attribute table with longitude and latitude of each point with the
> Field Calculator. I imported the attribute table into an MS Access database
> and used the Find Duplicates query wizard to find 11 pairs of duplicate
> points in 2052 total points. The points are needed for use with the Google
> Maps API.
> I tried the Vector/Topology Checker plug-in with a "must not have
> duplicates" rule to find the duplicate points and received a "0 errors were
> found" message.
> What am I missing when using the Topology Checker plug-in?
> Thank you.
> Robert Harris, Volunteer
> Georgia River Network
> http://www.garivers.org/
> Qgis-user mailing list
This transmission is intended for the named addressee(s) only and may
contain sensitive or protectively marked material up to RESTRICTED and
should be handled accordingly. Unless you are the named addressee (or
authorised to receive it for the addressee) you may not copy or use it, or
disclose it to anyone else. If you have received this transmission in error
please notify the sender immediately. All email traffic sent to or from us,
including without limitation all GCSX traffic, may be subject to recording
and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140310/34c7c757/attachment.html>
