[Qgis-user] Symbology Export
Jonathan Moules
jonathanmoules at warwickshire.gov.uk
Tue Mar 11 01:33:29 PDT 2014
Hi Joris,
Thanks, that's useful and kind of does what I want though it does seem to
have a number of bugs that mean I'm unlikely to be able to use it.
Don't suppose you (or anyone) knows where the tracker for it is? Its plugin
page points to itself being the tracker. :-S
Cheers,
Jonathan
On 10 March 2014 16:22, Joris HINTJENS <jh at enecowindbelgium.com> wrote:
> I use the plugin GEarthview for KML-KMZ export. It keeps the styling for
> polygones and attributes
> Joris
> Hi List,
> General curiosity question.
> When using "Save Vector Layer as" to save a vector layer, there's an
> optioon:
> "Symbology Export"
> This in turn has three options:
> "No Symbology"
> "Feature symbology"
> "Symbol layer symbology"
> What does this do? I've tried exporting to both KML and TAB files using
> these options but they don't appear to keep the symbology.
> Cheers,
> Jonathan
> This transmission is intended for the named addressee(s) only and may
> contain sensitive or protectively marked material up to RESTRICTED and
> should be handled accordingly. Unless you are the named addressee (or
> authorised to receive it for the addressee) you may not copy or use it, or
> disclose it to anyone else. If you have received this transmission in error
> please notify the sender immediately. All email traffic sent to or from us,
> including without limitation all GCSX traffic, may be subject to recording
> and/or monitoring in accordance with relevant legislation.
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140311/82c70493/attachment.html>
