[Qgis-user] Functionality matrix
James Wood
jwood911 at gmail.com
Wed Mar 12 03:32:00 PDT 2014
Might I also add that it is hard to generalize software functionality because of licensing levels and implementation tiers. Can I create Voronoi (Thiessen) polygons within ArcMap? Yes and no. I can with an Advanced license, but not if I have Basic or Standard. I don't have to worry about that with QGIS. Does the Esri software platform allow connection to PostgreSQL databases? Yes and no. I have an Advanced level license of ArcGIS Desktop installed on my laptop, but because I do not have an Enterprise-level ArcSDE installation, I cannot access my PostgreSQL database. QGIS allows me direct access without the fuss. Need to perform a simple task like converting your polygons to lines? You'll need an Advanced Desktop license in the "software that must not be named"... but it is as simple as Vector>Geometry Tools>Polygons to lines in QGIS (2.2). And, of course, depending on the desired result, there may not be a single tool within either software that gets you what you want. I have performed a lot of drive-time analysis for fire station ISO ratings, and right now, that's just easier in the Esri software, however I feel like improved support for that is on the horizon for QGIS along with some other more advanced analysis tasks. The easiest geocoder I ever used (for use with locally stored data) was in a previous version of MapInfo. There are strengths and weaknesses to go around, so instead of an overall matrix comparison, it might be more fruitful to look at your particular task-oriented functions and research those. In the end, you may find that a blending of different software is a best fit.
Best Regards,
James
> Date: Wed, 12 Mar 2014 07:46:51 +0100
> From: cavallini at faunalia.it
> To: qgis-user at lists.osgeo.org
> Subject: Re: [Qgis-user] Functionality matrix
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Il 11/03/2014 22:02, Anita Graser ha scritto:
> > Am 11.03.2014, 20:51 Uhr, schrieb Steve G <stevenlgolden at gmail.com>:
> >> I am
> >> seeking to find comparisons of functions in QGIS to another proprietary
> >> desktop GIS software provider (starts with "E", ends with "I").
> > Check
> > https://docs.google.com/spreadsheet/ccc?key=0Aho5SyzIJT5ydGFzUkk0SHpuYWxWS3dKVUtvT1JFLUE&usp=sharing
> Beware: functionality matrices sond good, but for complex programs are essentially
> unfeasible, unless one has months to dedicate to this effort. QGIS in particular is a
> fast moving target, as we are implementin g new functions very rapidly, so existing
> matrices are incomplete _and_ obsolete.
> All the best.
> Paolo Cavallini - www.faunalia.eu
> Corsi QGIS e PostGIS: http://www.faunalia.eu/training.html
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1
> Comment: Using GnuPG with Icedove - http://www.enigmail.net/
> iEYEARECAAYFAlMgAtsACgkQ/NedwLUzIr6DsgCdHQ8hfZeENppC4kUPlK/u5sB3
> b5gAn3lqlOVdcXgKX9Ixzpy7D3suQrdf
> =zAM+
> -----END PGP SIGNATURE-----
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140312/ba5a999d/attachment.html>
