[Qgis-user] QGIS Web Client for Windows 7
Bernhard Ströbl bernhard.stroebl at jena.de
Thu Mar 13 04:10:25 PDT 2014
Hi Markus,
I have no experience with QWC and Windows but maybe if you describe what
you have done and what happens you may get an answer from the list. Your
URLs are not accessible (time-out), at least for me.
More comments below
Am 13.03.2014 10:37, schrieb Markus Weidenbach:
> Dear List,
> for 2 days I was trying to get the QGIS Web Client running on my Windows
> 7 / Apache 2 system.
> I think I checked almost all comments and (still left open) questions on
> that issue on the web and this mailing list and my impression is, that
> nobody ever successfully installed the QGIS Web Client on Windows/Apache
> or am I wrong (?).
> So, before I change to 3Liz lizmap-web-client, this post is my last hope
> to get a positive answer ....
> My settings are:
> - Windows 7, 64 bit with QGIS 2.2 and _fully working QGIS Server_ on
> Windows/Apache (all updated/loaded on 10. March 2014 from OSGEO4W setup,
> QGIS Server and Apache loaded with OSGEO4W "Web GIS Fast Installation"
> setup mode).
> - QGIS Web Client downloaded ZIP from
> https://github.com/qgis/QGIS-Web-Client on 10. march 2014
> Like many other users I could successfully install the QGIS Server and
> display my *.qgs data as a map on the browser and also get the
> GetCapabilities information etc.
> If you find my server switched on you can check:
> http://landconsult.no-ip.com/qgis/qgis_mapserv.fcgi.exe?SERVICE=WMS&VERSION=1.3.0&SRS=EPSG:31467&REQUEST=GetMap&map=C:/OSGeo4W/apps/qgis/bin/wms_demo.qgs&BBOX=3453493.9,5358354.8,3461626.4,5363507.8&WIDTH=1000&HEIGHT=800&LAYERS=weg,bach&FORMAT=image/png
this is not Hello World, is it?
> But after the setting-up of the QGIS Web Client files under
> C:\OSGeo4W\apache\htdocs\QGIS-Web-Client-master and after adjusting all
> possible paths (including the right path in the GlobalOptions.js file at
> <<var serverAndCGI = "http://127.0.0.1/qgis/qgis_mapserv.fcgi.exe">> I
> was only able to see the QGIS Web Client interface but unfortunately not
> the default map "helloworld.qgs".
> http://landconsult.no-ip.com/QGIS-Web-Client-master/site/qgiswebclient.html?map=/Qgis-Web-Client-master/projects/helloworld.qgs
so do you get Hello world in another client (entering a GetMap request
in your Browser or QGIS desktop)?
Why are you not setting QWC on the project you mention above in order to
decide whether it is a server or client problem?
> So after all the reading and testing, I am not sure if QGIS WebClient is
> able to run on Windows/Apache at all?
> Is there anybody out there with a working QGIS Web Client on Windows/Apache?
> Thanks for your answers in advance (even if it is "no").
> Regards,
> Markus
Bernhard
__________ Information from ESET Security, version of virus signature database 9536 (20140313) __________
The message was checked by ESET Security.
    part000.txt - is OK
http://www.eset.com
