[Qgis-user] QGIs crashes opening old (2.0.1) projects in	valmiera (2.2.1)
    Alexandre Neto
    senhor.neto at gmail.com
    Thu Mar 13 04:52:19 PDT 2014
Hello Ariel,
Even in new installations the project fails to open and crashes.
As a workaround, I was able to open a new blank project, and add all layer
groups using embed
layer and groups...  and recreate part of the project, But all print
composers are lost, and probably other stuff that I'm not aware of now.
I think I will open a ticket for this, and do some more testings.
Thanks for your answer,
Alexandre
On Thu, Mar 13, 2014 at 8:21 AM, Rodriguez, A. <arielrod24 at gmail.com> wrote:
>  Alexander:
> Try to uninstall and re-install the software.
> Greetings and good luck.
> Ariel
> On 12/03/14 17:27, Alexandre Neto wrote:
>  Hello,
>  I'm having problems opening a Dufour project (2.0.1) in Valmiera (2.2.1)
> using windows 7 64 bit.
>  QGIS warns me that a older version project is going to be opened, but
> crashes during the reading of the layers. The same file still opens in
> 2.0.1 without problems.
>  Is there any known issues of lower versions compatibility? Any
> workarounds?
>  The problematic project is the following:
>  https://dl.dropboxusercontent.com/u/110618644/SIG_DTOP.qgs
>  Thanks,
>  Alexandre Neto
> Qgis-user mailing listQgis-user at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140313/c6a9b277/attachment.html>
