[Qgis-user] Trying to extract ocean part using Raster > Extraction > Clipper
Shriramana Sharma
samjnaa at gmail.com
Thu Mar 13 08:41:52 PDT 2014
Forwarding the reply to the list since it might be useful to others also:
On Thu, Mar 13, 2014 at 9:02 PM, Carol Kraemer
<cakraemer at northrivergeographic.com> wrote:
> Have you tried using the "Data Value" option either in the Clipper tool?
> Another option may be to go into the layer properties after you add the
> clipped image to QGIS. To do this, find out the value for the black region
> then go to Properties > Transparency and enter that value "Additional no
> data value" under the "No data value" section. That should allow you to see
> through the region.
Wow thank you very much! All I did was add a No data value of 0 and it
worked. Thanks thanks thanks! :-)
Shriramana Sharma ஶ்ரீரமணஶர்மா श्रीरमणशर्मा
