[Qgis-user] Export total image without requiring a composer?
Shriramana Sharma samjnaa at gmail.com
Thu Mar 13 18:40:00 PDT 2014
On Fri, Mar 14, 2014 at 12:02 AM, Carol Kraemer
<cakraemer at northrivergeographic.com> wrote:
> Would Project > Save as image.. in QGIS help you once you have set the map
> to the scale you want?
Hi thanks again for your reply. That probably would help but it
doesn't seem straightforward to control the output file image
dimensions from the scale. I found another way which does avoid the
compose and lets me control the extents and output file dimensions
correctly. Please find attached.
Shriramana Sharma ஶ்ரீரமணஶர்மா श्रीरमणशर्मा
Type: text/x-python
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140314/e1e4b1cd/attachment.py>
