[Qgis-user] QGIs crashes opening old (2.0.1) projects in	valmiera (2.2.1)
    Alexandre Neto
    senhor.neto at gmail.com
    Fri Mar 14 03:20:33 PDT 2014
Victor,
Thank you very much for your effort. I started that process at home, with a
ubuntu instalation and I was not able to complete it.
Meanwhile I have opended a ticket:
https://hub.qgis.org/issues/9779
I am going to try recreate a project with the same problem but with less
layers, in order to reduce the pain of trying to open it, and make testing
a bit more fast.
Thanks again,
Alexandre
On Thu, Mar 13, 2014 at 12:27 PM, Víctor Manuel Herreros Villanueva <
vherreros at ucm.es> wrote:
> Alexander,
> I've tried to open it under QGIS Valmiera, Windows 7 64 bit.
> I've had to click 'Cancel' for all of your layers database connections
> (cause I don't have your tables in my PostgreSQL Server) - patiently
> waiting more or less 30 seconds until my server time outs for each of your
> 22 tables.
> Then I got a 'missing file' error in QGIS (cause I don't have
> '//Fileserver/PRIVATE/Ortos/ORTOS2013/ortos2013.vrt' file on my
> filesystem). QGIS told me this layer would be lost, and I agreed.
> The I got a minidump, whose contents are inside the file uploaded here<http://www.mediafire.com/download/51qjs8257a63n6n/qgis-20140313-131106-4984-2232-c3a2817.dmp>,
> in case you want it for opening the ticket.
> And finally, QGIS closed.
> So I've not been able to open it.
> Sorry...
> 2014-03-13 12:52 GMT+01:00 Alexandre Neto <senhor.neto at gmail.com>:
> Hello Ariel,
>> Even in new installations the project fails to open and crashes.
>> As a workaround, I was able to open a new blank project, and add all
>> layer groups using embed
>> layer and groups...  and recreate part of the project, But all print
>> composers are lost, and probably other stuff that I'm not aware of now.
>> I think I will open a ticket for this, and do some more testings.
>> Thanks for your answer,
>> Alexandre
>> On Thu, Mar 13, 2014 at 8:21 AM, Rodriguez, A. <arielrod24 at gmail.com>wrote:
>>>  Alexander:
>>> Try to uninstall and re-install the software.
>>> Greetings and good luck.
>>> Ariel
>>> On 12/03/14 17:27, Alexandre Neto wrote:
>>>  Hello,
>>>  I'm having problems opening a Dufour project (2.0.1) in Valmiera
>>> (2.2.1) using windows 7 64 bit.
>>>  QGIS warns me that a older version project is going to be opened, but
>>> crashes during the reading of the layers. The same file still opens in
>>> 2.0.1 without problems.
>>>  Is there any known issues of lower versions compatibility? Any
>>> workarounds?
>>>  The problematic project is the following:
>>>  https://dl.dropboxusercontent.com/u/110618644/SIG_DTOP.qgs
>>>  Thanks,
>>>  Alexandre Neto
>>> Qgis-user mailing listQgis-user at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/qgis-user
>   <http://www.ucm.es/> *Universidad Complutense de Madrid*<http://www.ucm.es/>  *Víctor
> Manuel Herreros Villanueva*, PhD.
> Project Manager
> *Facilities ManagementData Warehouse*
>  Jardín Botánico
> Av. Complutense s/n
> 28040 Madrid
> Spain
> *Phn. no. (+34) 91 394 7275Fax no.  (+34) 91 394 4773*  vherreros at ucm.es
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140314/7f883a0f/attachment.html>
